The new displays just arrived. Will build a smaller version.
I think I will start a new project for this.
A project log for Arduino Glasses a HMD for Multimeter
Building an HMD with no special parts, to make work easier and safer
Link to these displays?
Hi alain, the picture after going through the reflected mirror, it will be reversed (right as left). Did you make the initial drawing reversed , to adjust this? Thank's
Hello Alain, i liked your project. Im also interested in this HMD field. I was looking for a starting point and i found your tutorial helpful. I was looking for possible displays recently. I have thought to work with this 0.5 inch full color display: http://www.alibaba.com/product-detail/Full-Color-OLED-microdisplay_673088898.html?spm=a2700.7724838.0.0.OrOwJA
But i realised its hard to drive. There also exist LCOS displays price around 80$ they are also below 0.5inch and full color. But they all need some expertise in display driving. Right now i will start working with your first 0.66 inch display to have an idea. I will be following your updates also.
Great. As you can see I am trying now this 0.49 Displays to reduce the size of the data glasses. I think I will do a PCB for this one. But the microdisplays you found seems to be a good starting point for a more evaluated data glasses.. In fact, I am not done with this project. It works really good, but I have a few changes in mind. I will move in a new house end of the month, so that I think the project will be on hold until January
I seen LCOS used with beam splitters, could work
Also it might be cheaper to buy a used pair of videoglasses to get the parts.
