The door opened / closed state, and the lock locked/unlocked state are detected with simple reed relays and optical gates.
The signal is transmitted with a 2 wire - industrial like - current loop circuit.
The optical gate transmitter circuit:
Using the current loop method it's easy to detect the short circuit and the cable-break states as well.
And the current-loop interface for the ESP8266 MCU module:
It uses a simple SPI 8 bit A/D converter from TI. ( ADC084S021 )
