Engraving in steel is possible but there seems to be a minute amount of slack. I just double-sided taped a metal spatula to a board for this.
A project log for K8200 3DRAG retrofit
Starting from the K8200 with a cnc mill, I added a loading system to accommodate boards of material to mill into and print on directly.
