I have started to assemble the very first module. It is made of 70 Panasonic NCR18650PF cells:
The bus bars are standard 10 X 3 mm² tinned copper bars. The total cross section is 60 mm².
![](https://cdn.hackaday.io/images/3027711473712891353.jpg)
Thanks to the assembly jig, the pitch of the nickel strips is precisely 19 mm. Welding the strips on the positive terminals of the cells is therefore very easy.
I weld twice every battery, resulting in four spots.
The very first welding spot.
The module is ready for positive terminals spot welding
70 Panasonic NCR18650PF cells inserted in their battery holder:
