The modules are ready for integration:
The modules weigh less than 3.7 Kg. Total weight will be of 15 * 3.7 = 56 Kg approx.
Spot welding the positive terminals of the Hybrid module:
The fuses are soldered on the copper bars thanks to the Jig.
The fuses (Negative terminal) are being welded:
