So much scientific research is locked up behind paywalls even when that research was paid for with public funds.
There is so much competition for public grants among scientists that they seem to only want pursue research that is "sexy" and likely to published in the most prestigious of journals--even when that research is flawed and sometimes dangerously fraudulent. Andrew Wakefield's MMR autism study was published in The Lancet in 1998 and was retracted in 2010 but to this day people still believe the Measles, Mumps, and Rubella (MMR) vaccine causes autism.
There is a growing citizen scientist (amateur scientist) movement spawned from the maker movement that is similar to the Gentleman and Lady scientists that preceded the Age of Enlightenment and before the professionalization of science. Citizen scientists are doing research that often rivals professional scientists and publishing their research in open journals and occasionally in prestigious scientific journals. Of course, most modern citizen scientists usually aren't wealthy like the early Lady and Gentleman scientists but nonetheless conduct their experiment with what ever they can scrounge together.
I think the Maker/DIY/hardware hacking communities inherently understand that a gizmo may look good on paper, but once you start building it, it may not turn out the way you planned. There’s a lot of troubleshooting between idea and prototype trying to figure out what went wrong during the build. You learn a lot from failure. Probably more than you will from success (and as is often said on Mythbusters, FAILURE IS ALWAYS AN OPTION). “Failure is part of science,” according to Stuart Firestein, “Without failures there would be no great discoveries.”
Science isn’t a spectator sport—you actually have to do science. Makers/DIYers/hackers prefer not to read about a device or watch others build their contraptions—they prefer to roll up their sleeves and build their own.
Welcome to the revolution.
