New Upgrade for the DAV5 V2.01 UV/VIS spectrometer
A project log for DAV5 V2.1 Spectrometer
The ZEN of simplicity Making the Complex...Seem Simple
david-h-haffner-srDavid H Haffner Sr 12/09/2017 at 22:310 Comments
I decided to get back to work on this project since I have a new contributing partner on board. The camera I am using for this is very low resolution I just wanted to utilize a different set up design using the new di-electric coated mirror ( 400-750nm) and Schott  glass filter attached to the focal lens.
Also it's not easy finding a webcam that works well with Spectragryph but this one works fine, so I'll use it for now until I find one that is at least a 5 mega pixel in resolution. The old JDEPC-05 board level camera, doesn't seem to work anymore with the new spectrometer software upgrade.
Well anyway here are some Solux lamp spectral images I captured today, ( 4700K, 50W and 12vdc 1.2A regulated power supply)
