FreeCAD v 0.16 - 10X Objective Lens Holder Assembly
A project log for DAV5 V2.1 Spectrometer
The ZEN of simplicity Making the Complex...Seem Simple
david-h-haffner-srDavid H Haffner Sr • 11/04/2016 at 08:39•0 Comments
3-D view of complete assembly of the 10X focal lens holder for the DAV5 V3 spectrometer. The holder has an attached rail [2mm width] rail slider that fits into the base, which allows for a 10mm total movement forward or backward in order to focus.
On the bottom which is depicted on the drawing, is an M3 mounting hole for a swivel insert in order to direct beam focus on second mirror.
