Bad flyback? [Video]
A project log for Tubeclock
Original name I know. Use a view finder CRT as the basis for a clock.
jeremy-gJeremy g. • 07/09/2016 at 07:10•0 Comments
so Im kinda stumped on this one. I'm pretty sure it's the flyback making the noise, but it may also be the high voltage plug into the bulk of the crt.. I can't quite pin point it.
I don't work on crts, I know there dangerous. Keep on hand in your pocket while working on them, this is know. I've been hit by one before and it does not feel good. I also proved all the grounds and the 12v line so I know those are hooked up fine.
Anyone have an idea? Is the crt dead or is it just the fly back?
Until then I will start in on the tiny crt again. And see what's going on with that one.
