If you plug in your eBay "Altera USB Blaster" and try to talk to you device, chances are you get an error such as this:
/opt/intelFPGA_lite/17.1/quartus/bin> ./jtagconfig -d
1) USB-Blaster [2-2]
Unable to read device chain - JTAG chain broken
Captured DR after reset = ()
Captured IR after reset = ()
Captured Bypass after reset = ()
Captured Bypass chain = ()
JTAG clock speed 6 MHzThis would usually indicate that something is wrong with your board, the power, the FPGA, or perhaps the programming cable. Don't despair!
There is a known issue which is still present in the latest versions of Quartus. It has to do with a library called libudev. It is easy to find solutions for various distros, but I haven't seen one specifically for Fedora (27). In my case, what worked was:
ln -s /lib64/libudev.so.1 /lib64/libudev.so.0
Now the board is detected and can be programmed.
What have I learned? If you can't 1-800-JTAG to your board, check with a known-good board to quickly find issues on the PC side.
Martin Cejp
thanks for the solution! i was going nuts as well!
in my case of ubuntu 21.04, libudev.so.1 was in /usr/lib/x86_64-linux-gnu/ instead
@dist.sys.engineer
I'm not sure I totally understood your error, but here are some things you could try:
1. Configure udev:
https://www.youtube.com/watch?v=hEi8nqpQv60
(you may need to reboot after configuring udev)
2. Plugging in stuff in the "right" order (this is what solved my problem on RHEL 8)
community.intel.com/t5/Intel-Quartus-Prime-Software/USB-Blaster-Unable-to-read-device-chain-JTAG-chain-broken/m-p/180907#M45366
(see the comment starting with "I find the issue: The USB-blaster must first be powered from the board and then connected to the PC.")
Good Afternoon and Thank You for helping resolve this issue.
I have tried everything, scouring the internet for days to use my Altera USB Blaster on Ubuntu 20. It works with the drivers on my windows machine but I do all of my development on my Ubuntu laptop. I have set the permissions, but I get an error message from dmesg|tail when I first plug in my device to my PC. Also, installed Quartus II, and jtagd --debug shows a message can't claim interface. jtagconfig says that the chain is already in use. I took screenshots and have them on my developer blog here
https://codeandbuildit.com/2021/01/27/fpga-buck-boost-01-27-2021-programming-fpga/
Any help is greatly appreciated. Kind Regards,
Thanks that worked for me! I was going nuts.
