My next task is going to make sure the Z-Rods are square with each other and stop them rattling. Also, my Z-Limit switch is starting to rattle loose so I need to fix that as well.
A project log for Monoprice Select Mini Upgrades
I've created this project to make the Monoprice Select Mini 3D a descent and affordable solution. For the $200 Price Range.
