So it works, but the wrenches flop around a little bit too much. I think in stead of slots for each wrench, I will use a clearance hole which will hold the wrench straight. I will still use an o-ring to hold tension on the wrenches and keep them from falling out. The o-ring may need to be tighter as well.
Alex Rich
