Considering parts
A project log for P.A.L. - Self Programming AI Robot
P.A.L. : Personable Autonomous Learning - Self Programming Robot that learns and grows - Each robot developes a unique personality.
thundersqueakThunderSqueak 06/24/2016 at 10:200 Comments
Currently I am attempting to do this project using components I already own. Upon scrounging through my parts I discovered a dozen stepper motors and matching controllers.
28BYJ-48 Stepper Motor and ULN2003
I am considering using these instead of much more expensive servos to control the neck functionality. If I use this setup, I may end up using a microcontroller as a small dedicated "servo neck controller" that directly interprets a standard servo signal from one of the pixy cameras.
Added:
After considering the options, I decided to go with a standard futaba servo, a 3003. The option of using a stepper was fine, however I would have had to tap into the accelerometer in order to find out where the stepper motors were. That or find another way to track their motion. Servo it is.
Rich text editor
