Partial Parts order completed, now just to wait :)
A project log for P.A.L. - Self Programming AI Robot
P.A.L. : Personable Autonomous Learning - Self Programming Robot that learns and grows - Each robot developes a unique personality.
thundersqueakThunderSqueak 07/06/2016 at 02:200 Comments
I ordered some parts today to get some of the subsystems built.
Systems that are ordered are the Motor Controller for the main drive motors. I went with
http://www.robotshop.com/en/sabertooth-dual-2x32a-6v-24v-regenerative-motor-driver.html
2cm - 10cm Infrared Distance SensorDC-DC Power Converter 25WStep-Up / Step-Down Voltage Regulator S7V7F5HC-SR04 Ultrasonic Range Finder2.54mm JST Connector Kit
For the speech system I ordered
8 pin socket
18 pin socket
20 pin socket
28 pin socket
2n3904
10k resistors
100k resistors
47k resistors
.1uF capacitor
33pF capacitor
.47uF capacitor
250uF capacitor
Electret microphone
MSGEQ7
I already have the 8 ohm speaker, 2 pin screw terminal blocks, header pins, TTS256, speakjet, and lm386
As soon as the main lower chassis arrives, which should be late this week or early next week I will get that portion assembled and begin work on the robot's body frame and limbs.
I had an odd thought today about the grippers, and was considering using a padded finger tip with a very tiny magnet in it and a hall effect sensor. When the hand is closed the padded fingerip will "feel" the pressure and respond accordingly. If I use a rubberized pad, it will also give the robot some extra grip and mold around the object the robot is picking up. I will think more about this when the time comes.
Rich text editor
