So where will pollution data go?
We decided to send them to Adafruit IO.
Here's why:
- our favourite fruit is Adafruit ;)
- all IoT things should talk IoT protocols; Adafruit IO talks MQTT
- available open source libs and learning resources
- cool web widgets to display the data
That said, please note that Adafruit IO is still in beta.
So, here are the feeds:
https://io.adafruit.com/jalmasi/feeds/co
https://io.adafruit.com/jalmasi/feeds/co2
https://io.adafruit.com/jalmasi/feeds/h2s
https://io.adafruit.com/jalmasi/feeds/o3
https://io.adafruit.com/jalmasi/feeds/c6h6
https://io.adafruit.com/jalmasi/feeds/pm
https://io.adafruit.com/jalmasi/feeds/temp
They are all public, or are supposed to be.
Our initial attempt to send the data failed, due to chicken-egg problem:
we use SoftwareSerial to drive ESP8266. ESP8266 works on 115200 bps by default, and highest accurate boud rate available with SoftwareSerial is about 38400.
Our attempt to change baud rate to 19200 resulted in two fatalities, now we have to upload firmware to two ESP8266 modules.
So, no data yet :(
Probably tomorrow;)
But FTR, here's the code for MQTT over SoftwareSerial ESP8266.
// https://github.com/Diaoul/arduino-ESP8266
#include <ESP8266Client.h>
#include <SoftwareSerial.h>
#include "Adafruit_MQTT.h"
#include "Adafruit_MQTT_Client.h"
// wifi setup
#define WIFI_SSID "krbljovrtislav"
#define WIFI_PASSWORD "Kobasica"
//SoftwareSerial softSerial(3, 2); /* RX:D3, TX:D2 */
SoftwareSerial softSerial(2, 3); /* RX:D3, TX:D2 */
ESP8266 wifi(softSerial);
/************************* Adafruit.io Setup *********************************/
#define AIO_SERVER "io.adafruit.com"
#define AIO_SERVERPORT 1883 // use 8883 for SSL
#define AIO_USERNAME "supersecret"
#define AIO_KEY "SuperSecretAndLongKeyImpossibleToGuess"
// Create an ESP8266 WiFiClient class to connect to the MQTT server.
//WiFiClient client;
// or... use WiFiFlientSecure for SSL
//WiFiClientSecure client;
// Store the MQTT server, username, and password in flash memory.
// This is required for using the Adafruit MQTT library.
const char MQTT_SERVER[] PROGMEM = AIO_SERVER;
const char MQTT_USERNAME[] PROGMEM = AIO_USERNAME;
const char MQTT_PASSWORD[] PROGMEM = AIO_KEY;
ESP8266Client client(wifi);
// Setup the MQTT client class by passing in the WiFi client and MQTT server and login details.
Adafruit_MQTT_Client mqtt(&client, MQTT_SERVER, AIO_SERVERPORT, MQTT_USERNAME, MQTT_PASSWORD);
/****************************** Feeds ***************************************/
// Notice MQTT paths for AIO follow the form: <username>/feeds/<feedname>
const char CO_FEED[] PROGMEM = AIO_USERNAME "/feeds/co";
Adafruit_MQTT_Publish co_feed = Adafruit_MQTT_Publish(&mqtt, CO_FEED);
const char CO2_FEED[] PROGMEM = AIO_USERNAME "/feeds/co2";
Adafruit_MQTT_Publish co2_feed = Adafruit_MQTT_Publish(&mqtt, CO2_FEED);
const char H2S_FEED[] PROGMEM = AIO_USERNAME "/feeds/h2s";
Adafruit_MQTT_Publish h2s_feed = Adafruit_MQTT_Publish(&mqtt, H2S_FEED);
const char O3_FEED[] PROGMEM = AIO_USERNAME "/feeds/o3";
Adafruit_MQTT_Publish o3_feed = Adafruit_MQTT_Publish(&mqtt, O3_FEED);
const char C6H6_FEED[] PROGMEM = AIO_USERNAME "/feeds/c6h6";
Adafruit_MQTT_Publish c6h6_feed = Adafruit_MQTT_Publish(&mqtt, C6H6_FEED);
const char PM_FEED[] PROGMEM = AIO_USERNAME "/feeds/pm";
Adafruit_MQTT_Publish pm_feed = Adafruit_MQTT_Publish(&mqtt, PM_FEED);
const char TEMP_FEED[] PROGMEM = AIO_USERNAME "/feeds/temp";
Adafruit_MQTT_Publish temp_feed = Adafruit_MQTT_Publish(&mqtt, TEMP_FEED);
void setup() {
Serial.begin(9600);
softSerial.begin(115200);
wifi.begin();
// setWifiMode
Serial.print("setWifiMode: ");
Serial.println(getStatus(wifi.setMode(ESP8266_WIFI_STATION)));
Serial.print("joinAP: ");
Serial.println(getStatus(wifi.joinAP(WIFI_SSID, WIFI_PASSWORD)));
// getMAC
byte mac[6];
Serial.print("getMAC STA: ");
Serial.print(getStatus(wifi.getMAC(ESP8266_WIFI_STATION, mac)));
Serial.print(" : ");
for (uint8_t i = 0; i < 6; i++) {
Serial.print(mac[i], HEX);
if (i < 5) Serial.print(":");
Serial.println();
// getIP
IPAddress ip;
Serial.print("getIP STA: ");
Serial.print(getStatus(wifi.getIP(ESP8266_WIFI_STATION, ip)));
Serial.println(ip);
int32_t coVal, co2Val, h2sVal, o3Val, c6h6Val, tempVal = 0;
void loop() {
// Ensure the connection to the MQTT server is alive (this will make the first
// connection and automatically reconnect when disconnected). See the MQTT_connect
// function definition further below.
MQTT_connect();
// Now we can publish stuff!
publish( co_feed, coVal++ );
publish( co2_feed, co2Val++ );
publish( h2s_feed, h2sVal++ );
publish( o3_feed, o3Val++ );
publish( c6h6_feed, c6h6Val++ );
publish( temp_feed, tempVal++ );
// sleep a bit
delay(2000);
void publish(Adafruit_MQTT_Publish feed, int32_t val) {
if (! feed.publish(val)) {
Serial.println("Failed");
} else {
Serial.println("OK!");
// Function to connect and reconnect as necessary to the MQTT server.
// Should be called in the loop function and it will take care if connecting.
void MQTT_connect() {
int8_t ret;
// Stop if already connected.
if (mqtt.connected()) {
return;
Serial.print("Connecting to MQTT... ");
uint8_t retries = 3;
while ((ret = mqtt.connect()) != 0) { // connect will return 0 for connected
Serial.println(mqtt.connectErrorString(ret));
Serial.println("Retrying MQTT connection in 5 seconds...");
mqtt.disconnect();
delay(5000); // wait 5 seconds
retries--;
if (retries == 0) {
// basically die and wait for WDT to reset me
while (1);
Serial.println("MQTT Connected!");
// ESP8266Client utilities
String getStatus(bool status)
if (status)
return "OK";
return "KO";
String getStatus(ESP8266CommandStatus status)
switch (status) {
case ESP8266_COMMAND_INVALID:
return "INVALID";
break;
case ESP8266_COMMAND_TIMEOUT:
return "TIMEOUT";
break;
case ESP8266_COMMAND_OK:
return "OK";
break;
case ESP8266_COMMAND_NO_CHANGE:
return "NO CHANGE";
break;
case ESP8266_COMMAND_ERROR:
return "ERROR";
break;
case ESP8266_COMMAND_NO_LINK:
return "NO LINK";
break;
case ESP8266_COMMAND_TOO_LONG:
return "TOO LONG";
break;
case ESP8266_COMMAND_FAIL:
return "FAIL";
break;
default:
return "UNKNOWN COMMAND STATUS";
break;
String getRole(ESP8266Role role)
switch (role) {
case ESP8266_ROLE_CLIENT:
return "CLIENT";
break;
case ESP8266_ROLE_SERVER:
return "SERVER";
break;
default:
return "UNKNOWN ROLE";
break;
String getProtocol(ESP8266Protocol protocol)
switch (protocol) {
case ESP8266_PROTOCOL_TCP:
return "TCP";
break;
case ESP8266_PROTOCOL_UDP:
return "UDP";
break;
default:
return "UNKNOWN PROTOCOL";
break;
mikrotron
