400 Watt white LED light (Photon Blaster V3)
A project log for Aeroponic All-year Greenhouse on a Budged
My adventures in Aeroponics are now in V4.0
hyperkantehyperkante • 07/11/2016 at 22:43•0 Comments
Okay as promised: LEDs !!
ok, maybe not a lot of them, but they are rated for 100Watt power consumption.
To simulate sunlight during short winter days, i decided to build a LED light for my plants.
I had 3 big aspects: Price, Efficiency and Cooling (LEDs do get hot!)
ok first the Budged: a lot of growers use full-spectrum Leds. They have a combination of red,blue, IR, and UV light, specially designed for plants. BUT, they are pretty expensive (about 2-5€ per Watt)
My chinese electronics shop of trust, sells 100 Watt led chips for under 10€ and they even have cheaper deals. But in case of a failure, it is easier to replace one 10€ led instead of testing hundreds of 1watt leds. And for my design, few big chips are easier to install. ( i allready soldered thousand of leds by hand, getting tired of it... )
Efficiency: The spectrum of the white leds doesnt have to much of green light (wich is mostly reflected by green plants), but full spectrum LEDs waste almost no Energy.
That said, i think the Photon Blaster is way better than a High Pressure Sodium Lamp of the same Power, because it radiates way less heat, more Lumen and can be dimmed or pulsed.
Cooling: Since this isnt my first LED light, not even the first with these 100 Watt chips, i know these chips use some serious Cooling. There are people on the net, building Flashlights with these chips. The cooling is usually to small, but it doesnt matter because the Batteries are dead, before the Flashlight gets hot.
In my case, the Light will be running at least 16h without cooldown. So the cooling system should be able to hold the chips cool forever. First i tried CPU cooler, because the chips are a similar size than CPUs, but they are a pain to mount. So for this build i went to the local scrapyard and got some massive Aluminium Heatsinks. For future builds i would love to try water cooling, but im still looking for cheap parts.
ok enough talk, lets build a Light:
In the picture above you see my big ass heatsink, the LEDs and the LED-Drivers.
Since im re-using some of the LEDs and Drivers from the Photon Blaster V2 (R.I.P.), they are still wired together. The wiring is super simple: all AC lines together to a Standard EU-Plug and every driver has Positive and Negative Wire clearly marked. Solder them to the LEDs, while not attached to the Heatsink.
Next i marked all my holes to drill. 3.5mm Holes were Drilled (picture below)
The Heatsink was quite big and heavy, but i got it clamped down to drill.
After Drilling, the holes were drilled with a M4 Thread, to hold the Leds later with some stainless steel srews. I decided to tighten the chips with only 2 screws, but i recomend all 4 screws.
Here you can see how the chips going to get mounted. The Driver have small Heatsinks, that will be pressed against the big one. The two Leds in the middle are warm-white and the outer ones are cold-white.
The Chips are Mounted. Dont forget Thermal Paste, or your chips are gonna have a short life.
The LED-Driver are mounted on the side of the Heatsink. I drilled 3.5mm holes for cable ties and also attached holders for the Fans.
M4 Screws hold a bend piece of Metal in place. Later we will attach the Fans on these holders.
Here is a view of the Backside with all 4 Drivers in place, a 12V Power Supply (left side) will power 4 Fans.
The Front view. Dont look directly in the LED light! These chips are spitting 9000 Lumen at you....each!
The Cooling system consists of 4 80mm Computer Fans. All wired together, simply running on maximum RPM, whenever the Light is on. To hold them together, i used cable ties.
Here you see the final Photon Blaster V3!
The Fans are installed and for the first test i had a close look at the Temperature. The Heatsink stays steady at about 36°C after 1 Hour. Longterm Tests will continue.
With a distance of about 65cm, i measured about 30.000 Lux. I Measured the Sun with about 100.000-150.000 Lux in Summer. Not quite as bright as the Sun, but maybe enouth to fool my plants.
I want to build another Light soon. This time with a big blue LED and some smaller red ones. Trying to clone the Full-spectrum LEDs on the Cheap.
Also im gonna build 3 Test chambers to play around with different light combinations, to see wich is the best for my plants. So stay tuned.
-see you next Mission
aka
