It works! We're currently running it at 100PSI and even at that pressure it is capable of curling a battery that weighs 67lbs!
These cylinders are rated for 250PSI, so hypothetically we could lift over 150lbs! Per arm!
A project log for Pneumatic Exoskeleton
Vaguely based off of the exoskeleton from Elysium
