In order to reduce agricultural water cost, soil moisture should be measured by affordable low-cost sensors. As well as gypsum soil moisture sensors in Vinduino project, this project tries to build soil moisture sensors. There is research demonstrates that it is possible to measure soil moisture by soil capacitive and employs capacitive touch sensor for that task. From that research, improvement for how to build (easily, for example: using PCB), how to install sensors, contact between sensors and soils (mentioned in that research).
ohmohm
Ward Almasarani
mircemk
Jan
Keerat Singh
