Serial output from the usb dongle
| Dongle Firmware | https://github.com/nRFMesh/nRF52_Mesh/tree/master/applications/08_usb_dongle |
cu can be used to check the output. Hint, stop serial with "~."
cu -l /dev/ttyACM0 -s 460800
Then start a python service to translate the serial to mqtt
| Python script | https://github.com/HomeSmartMesh/raspi/blob/master/py/nrf_mesh/nrf_mesh.py |
python3 py/nrf_mesh/nrf_mesh.pymosquitto_sub -t 'nrf/#' -v | tsThe "| ts" is a pipe that adds timestamp
subscribing to the mqtt topic would then show an output format inspired from zigbee2mqtt that allows to mix the custom nrf devices into the rest of the automation chain
used sensors
more details about the RF and serial protocol in https://www.homesmartmesh.com/mesh/
Wassim
