Just submitted GadgetBox V1.7 - Hopefully this will be the last revision before I do a run of 100.
Here are a list of changes:
7/11/2016 V1.7 GadgetBox
- Renumbered all components
- Added On/Off to BL Quadrant.
- Consolidated components to a single type for 10K and 10uF.
- Moved Quadrant silkscreen to layer 200 instead of 21.
7/6/2016 V1.6 GadgetBox
- Changed size of board to fit white cases. 93.5x53.5
- Added voltage divider to allow capturing battery power on pin D5.
- Added all BOM info.
- Rerouted 3.3v and GND to provide better paths.
- Moved location of components for the BH silkscreen and the new board size.
