First GadgetBox project: Remote Control.
A project log for GadgetBox - No More Shield Stacking or Ugly Wires!
Build your IOT projects with Universal eCog modules that simply snap into low cost enclosures.
jack-gassettJack Gassett • 08/06/2016 at 17:17•0 Comments
Here is a quick video showing the first working GadgetBox using a pCog (project Cog) design to implement a working remote control solution. A pCog is four eCogs that are manufactured together and can be snapped into four separate eCogs if desired. For example the eCog in the upper left quadrant of the pCog is a blank eCog, if we wanted to add a display instead we would just snap the pCog apart and replace the blank portion with a display eCog.
