Added two scaled drawings of the fuselage-to-be, after adapting the earlier referred to plans and mashing some other stuff in.
Will probably still modify if, it is by no means a finished design.
In the electronics front, will order a motor (BLDC, 12v, 2200 Krpm per volt) + 30 A rated ESC from our good friends from shenzen or nearby.
Battery will probably be sourced from cell phones or the like.
Will start (and hopefully finish) building the actual aircraft in the next week(s)
Soldered enough of the main boards of the plane and controller to start testing the radios and control protocols. Coding ensues.
