I am working on a better version of the user interface that is displayed on the FPV receiver.
Looking at the PiCamera Python package documentation, I found that I can create multiple overlays and control their precise dimensions and positioning. Not making overlays fullscreen allows to have clear central frame and information above and below the frame: http://picamera.readthedocs.io/en/release-1.10/api_renderers.html#picamera.renderers.PiRenderer
Using this, and also using a crosshair image, you can create a better looking UI for the display. Here's the code that I used to create display in the image below:
#!/usr/bin/python
import picamera
import time
import numpy as np
import string
import random
import os
from PIL import Image, ImageDraw, ImageFont
# Video Resolution for recording
VIDEO_HEIGHT = 940
VIDEO_WIDTH = 1280
baseDir='/home/pi/osd/' # directory where the video will be recorded
os.system('clear') # clear the terminal from any other text
# Create empty images to store text overlays
textOverlayCanvas = Image.new("RGB", (704, 60))
textOverlayPixels = textOverlayCanvas.load()
# Use Roboto font (must be downloaded first)
font = ImageFont.truetype("/usr/share/fonts/truetype/roboto/Roboto-Regular.ttf", 20)
with picamera.PiCamera() as camera:
camera.resolution = (VIDEO_WIDTH, VIDEO_HEIGHT)
camera.framerate = 60
camera.led = False
camera.start_preview()
topText = "Alt: 310m Spd: 45km/h Dir: N"
bottomText = "47.6062 N, 122.3321 W Home: 322m Rec: 3:22"
topOverlayImage = textOverlayCanvas.copy()
bottomOverlayImage = textOverlayCanvas.copy()
# Load the crosshair image
crosshairImg = Image.open('crosshair.png')
# Create an image padded to the required size with
crosshairPad = Image.new('RGB', (((crosshairImg.size[0] + 31) // 32) * 32, ((crosshairImg.size[1] + 15) // 16) * 16))
crosshairPad.paste(crosshairImg, (0, 0))
# Attach overlays
topOverlay = camera.add_overlay(topOverlayImage.tostring(), size=(704,60), layer=3, alpha=128, fullscreen=False, window=(0,20,704,60))
bottomOverlay = camera.add_overlay(bottomOverlayImage.tostring(), size=(704,60), layer=4, alpha=128, fullscreen=False, window=(0,500,704,60))
crosshairOverlay = camera.add_overlay(crosshairPad.tostring(), size=(704,512), layer=5, alpha=10, fullscreen=False, window=(20,30,704,512))
try:
while True:
drawTopOverlay = ImageDraw.Draw(topOverlayImage)
drawTopOverlay.text((200, 15), topText, font=font, fill=(255, 0, 255))
topOverlay.update(topOverlayImage.tostring())
drawBottomOverlay = ImageDraw.Draw(bottomOverlayImage)
drawBottomOverlay.text((150, 20), bottomText, font=font, fill=(255, 255, 255))
bottomOverlay.update(bottomOverlayImage.tostring())
time.sleep(1)
except KeyboardInterrupt:
camera.remove_overlay(topOverlay)
camera.remove_overlay(bottomOverlay)
camera.remove_overlay(crosshairOverlay)
print "Cancelled"
finally:
Next steps would be to display information from the GPS sensor attached to the Raspberry Pi via serial interface.
