Why?
The reason behind the design of the portable power supply is simple: To provide access to a highly portable, variable power supply to engineers, students and hobbyists building and programming electronics in spaces where a typical power supply is difficult or impossible to use (remote areas, small labs, on-the-go programming, etc). With the addition of a highly accurate current measurement module and Bluetooth connectivity, users can monitor the power consumption of their devices while programming, debugging or during deployment in the field.
Features
- 0 - 12V regulated output voltage
- 0 - 2A current output with current limiting function
- E-Paper Display
- Current measurements down to micro Amps, maybe nano Amps
- Bluetooth Connectivity
- Sub 1-GHz connectivity (optional)
- Fixed 5V USB output connection
- Micro USB connector for serial output
- Lithium Ion battery pack
- Power supply connector (used for charging)
Hardware Design
Firmware
The firmware for this project will be uploaded and updated through GitHub https://github.com/James-Bonds/pps
Applications
- Bench power supply
- Power small electronics during prototype stages
- Evaluate and monitor device consumption while programming firmware
- Portable power supply for in-field testing and debugging
- Power supply for outdoor designs
- Remote monitoring of devices
Schematics
Alex Xia
Arnov Sharma
Denis
Lithium ION
How did this project go? Any progress?
