i want to make a hack rf by using the fluctuations of transistor when the light is turn-off the sensor(i have a difference diagram which not use the led,just need to use two transistors to make fluctuation),but i don't sure is that will work as a fluctuation machine or emits the electromagnetic waves?so i need your development and a suggestion,thank.
