I get my raw TOF sensors, and i ask me if i can solder it, The pitch is 0.45 mm. I knew this sensors are small - but to see it...
Next steps are:
selecting Components
electrical and optical
PCB design ......
My question is : from where can i get cheap fixfocus glass lenses?
The type used in piCamera module could be usable if glass lenses are used.
Anyone could give me some info where i can find?
Frank.Muenzner
Thanks for your help.
The link to surplusshed is interesting.
For this project i want to use a standard mount because of availability and reproducibility.
Edmund optic i knew, but as you said not for low cost.
I think i will use a classic M12 or M7 / M8 mount.
For the firts sample i will use a M12 mount lens system, from Eric's link.
Ted, I really like your 3D magnetic field scanner project, it's amazing.
I've purchased cheap (surplus) lenses from these places:
http://www.surplusshed.com/ (some really good bargains here if you look hard enough. Check out their "lens finder")
http://www.edmundoptics.com/clearance-products/ (this used to be anchor optical surplus)
For top-quality (and top-dollar), of course, you can't beat Edmund:
http://www.edmundoptics.com/ very expensive
The other thing you might consider is using a standard C- or CS- lens mount. Then you could use a wide variety of lenses on your device. Cheap CS-mount lenses are made for security cameras, and C-mount (same thread, different flange distance) used to be a 16mm movie camera standard, so old lenses are cheap on ebay.
