For the end of this year I would like to share with you a simple solution for multi channel separation of single LED source.
(it operates on 14MHz pulse per channel with 30% Duty and phase shift of 120deg per channel)
Happy New Year.
A project log for Visible Light Communication for the masses
This project will focus on making current research in field of Visible Light Communication (VLC and LiFi) usable and meaningful for use...
Happy New Year.
Thank you for info :) ... I thought that it is "All rights reserved" sign.
You do realize that (R) is registered trademark symbol? Trademarks unlike Copyrights do not have year specified as they do not expire because of time.
https://en.wikipedia.org/wiki/Registered_trademark_symbol
vs https://en.wikipedia.org/wiki/Copyright_symbol
