Arduino UNO Mini-Weather Station
A simple Arduino based mini-weather station with wi-fi connection for micro-climate monitoration
Climatic monitoration is a great concern, specially in big cities around the world that suffer with air polution issues and drastic climate changes throughout the years. Besides that, most of small cities doesn't dispose of a local weather station and there is a lack of data for public analysis.
This project aims to create an affordable Arduino based weather station, with wi-fi connection, able to post data publicly online using ThingSpeak platform. The weather station is able to collect local temperature, humidity, atmospheric pressure, light intensity, UV index and dust concentration.
This is the first generation of my Arduino based mini-weather station with wi-fi connection, which is able to post data publicly online using ThingSpeak platform.
The weather station collects the following data related to the weather and environment using different sensors:
  • Temperature;
  • Humidity;
  • Atmospheric pressure;
  • Light intensity;
  • UV index;
  • Dust concentration.
The aim is to make a small and simple weather station, using open hardware.
No specific tools are required for the assembly of this project. All the components can be found online.
The circuit is powered by the USB port (connected to a computer or a ordinary phone charger), but you may also add an external DC power supply or a battery connected to the Arduino power jack.
A case for the weather station circuit was not developed yet.
First online station: https://thingspeak.com/channels/35540
View all 10 components
View project log
View all instructions
