A note on part substitutions:
The components list is the specific parts I'm using in my prototyping build. Lots of the parts can be swapped if that is your preference. As I write the build manual I'll try to note when a part or process can be handled differently.
Mugsy can run headless so a screen is not necessary. It defintely makes it cooler though....
