The Power Regulator:
The MAX 882: This is a 3.3 V, 220 mA LDO that was designed to be run off of a battery. It uses a P-Channel FET to consume a max of 15 uA during operations, has a typical drop out voltage of 220 uV and has a variable output among other features. In this case I set the output to 210 mA, and told it to go into standby when the batteries output hits 3.14 V, no reason to kill the battery if I forgot about ti for a little while.
Unlike a lot of other regulators, it does NOT care about the ESR of it's input/output capacitors, as long as the minimum values are met. This meant that I could use electrolytic caps as long as I was careful to de-rate them for temperature. Most likely I will end up adding a ceramic or tantalum in parallel just to be one the safe side.
Yes, I know switchers are more efficient, but you've got to remember that this things entire purpose is to power a Blue Tooth module and I want a power supply that is as clean as I can get. Short of heroic efforts, a switching power supply will always generate more noise, and I'm lazy.
Next up, laying out the system.
