Note 1: I capitalize "X-axis", "Z-height" and the like for legibility when scanning/skimming; pedants can hate me later.
Note 2: This is part one where measurements and construction details of the mechanical structure are listed. Idealistic modifications are in Part 2.
Disclaimer: Due to human error but mostly manufacturing tolerances, the following apply.
- Diameters/measurements under 50 mm have a +/-0.05 mm tolerance
- Lengths over 100 mm have a +/- 1 mm tolerance
Hey, the title for the project is 'Electro-mechnical' so it's about time I make good on the latter half, no? Before anything can be modded, we need to have a close look at what the mechanical structure is and then adjustments can be made from there.
So the M200 printer went through a couple of revisions more likely than not. We know that the electronics were built to a cost and possibly the hardware was too. There haven't been any major problems that result from it's industrial design, but is there evidence of slimming the cost of parts?
I want to bump any and all of the 3 axis to larger dimensions so this Mini can print larger than mini, so lets take a closer look at the axis construction. The Z-axis & A-axis are where we have custom parts that if you irreparably damage, you'd have to buy a new printer or hope someone can print replacements, which no one has dropped into CAD yet. We have graphite composite for these pieces to assure rigidity and thermal resistance; especially since the X-axis motor mounts to the Z-axis carriage. This latter portion I'll touch on after listing a few details of the linear shafts used.
There are 7 shafts, 2 belts, and 1 threaded rod that are responsible for the physical movement of the printer, excluding eh extruder. Here are their details:
- Upper X-axis shaft: 6 mm diameter, 209 mm long, count of 1
- Mounted in 1 location in Z-axis carrier and in X-axis end cap via interference fit & adhesive
- Lower X-axis shaft: 6 mm diameter, 287 mm long, count of 1
- Mounted in 2 locations in Z-axis carries and in X-axis end cap via interference fit & adhesive
- Front Z-axis shafts: 6 mm diameter, 246 mm long, count of 2
- Mounted to prevent radial play at the top and bottom of the tower
- Rear Z-axis shaft: 6 mm diameter, 246 mm long, count of 1
- Y-Axis shafts: 8 mm in diameter, 187 mm length, count of 2
- Mounted in end caps on bed carrier
- Linear bearings are LM8LUU mounted to the chassis via bearing blocks
- Z-axis movement: M4x0.7 threaded rod, 192 mm long
- Partially magnetic, assuming poor quality steel or a 400-series stainless. Metal flecks are prolific in the current grease so I assume the former
- 8 mm OD solid brass coupler w/ 2 M2.5 set screws & thread lock to connec to Z-axis motor, brass flange nut on Z-axis carrier
- X-axis movement: B236MXL 052 timing belt. Outside circle of ~9.8", 5 mm wide. The following belts are not "direct" replacements. This is discussed in Part 2.
- A 236MXL belt made from neoprene on McMaster's site have 295 teeth, not the desired 236
- The urethane belt 235MXL is a rather suitable replacement
- The neoprene belt 200MXL may work with additional tensioner(s) as it is about 0.2" too long
- There are 17 teeth on the X-axis motor pulley and the freewheelin pulley in the end cap
- Y-axis movement: B236MXL 052 timing belt. Cut length to 259 mm and 5 mm wide
- Given the use of zip ties and the length of the bed carrirer, 205-215 mm of length would be required for replacement
- There are 17 teeth on the X-axis motor pulley and the freewheeling pulley in the end cap
Stock Z-axis
The Z-axis carriage has space for 3 linear bearings, all of which are LM6LUU's, which are basically 2 LM6UU's stacked end-to-end. Two of these bearings are sitting closest to the printer bed to provide additional riidity as this is the natural fulcrum of the A-axis arm. The third is by its lonesome self near the Z-axis limit switch. For the front two, the composite has a thickness of 17-17.75 mm and the rear has a thickness of ~20 mm.
The mounts for the shafts are relatively simple pieces of steel with press-fit hex stand off nuts. Their purpose is to prevent radial movement of the shafts. There is a rattle in the printer since there is no axial play prevention from the mounts. If you look closely though, the front mount brackets have a width of about 9 mm. However, the rear mount brackets has a width of 11 mm. Given the symmetry of these differences and the Z-axis carrier, I'm willing to bet that an 8 mm rod was used in the back at some point in the design and they just never adjusted the carrier's mold.
