- Added more settings to the EEPROM functions
- Modified "count" command to accept an argument to manually set the count
- Added "silent" command to toggle the buzzer audio on or off
- Added "restore" command to reinitialize the EEPROM
- Added "eeprom" command to show the contents of the EEPROM
- Added 'version' variable to use to determine when to upgrade EEPROM values
