- Fixed issue when initializing and setting up the IP Address
- Fixed issue changing SSID from the console
- It would change it in the configuration and save it but it would not make it active - Updated some deprecated calls with the JSON object
A project log for ESP8266 Mobile Rick Roll Captive Portal
A fun project to Rick Roll friends or strangers wirelessly.
