Solar Irradiance across the world
A project log for Artificial plant sunlight (obsolete)
A development of a low cost, high efficiency LED growing lightning that will meet the needs of the plant.
domenDomen • 07/17/2016 at 08:58•0 Comments
Annual surface solar irradiance received in 2008. The equator receives solar radiation at a higher intensity (irradiance) than the norther and southern hemispheres. Data compiled by P. Wang, P. Stammes, R. van der A, G. Pinardi, M. van Roozendael (2008), FRESCO+
Solar irradiance is the intensity with which radiation enters Earth’s atmosphere. An relatable way to think about solar irradiance is by looking at the difference between a 20-watt light bulb and a 100-watt light bulb. Both produce visible light in the same wavelengths, but the brightness and intensity are very different. The 100-watt bulb has a higher intensity, or irradiance. Solar irradiance is the amount of radiant flux on an area, and is measured in watts per meter squared (W/m²)9.
Source of the quote and the picture: http://www.fondriest.com/environmental-measurements/parameters/weather/photosynthetically-active-radiation/
