This project is pointless and finished
A project log for Artificial plant sunlight (obsolete)
A development of a low cost, high efficiency LED growing lightning that will meet the needs of the plant.
domenDomen • 07/17/2016 at 09:50•0 Comments
I have found out by just looking at the specifications of solar irradiation that any sort of artificial light that would mimic the sun would use up a lot of energy per m^2 which is simply not worth it since growing under the sun is cheap and easy.
The current growing LED modules you can find on Ebay that are rated 150W - 300W would probably be sufficient for any type of growing so there is no need for a development of such a solution I previously proposed.
I also can not see the point of skyscrapers growing food, where they use artificial lightning. They should rather build greenhouses I think. I'm open to any criticism.
EDIT: Maybe it is efficient because they use so few of the LEDs? I am not sure.
