Toshiba TCD1304
A project log for Handheld VNIR Spectrometer
A small portable spectrometer that can be used in the field to collect spectral data.
adamAdam • 02/26/2018 at 15:15•2 Comments
For a number of reasons including product availability and cost I decided to swap out the Sony ILX11B CCD in my spectrometer for a Toshiba TCD1304. Additionally there are a number of other DIY spectrometer projects that use this part making it easier to develop code to drive and read from the CCD. Because of timing requirements on the TCD1304 I can no longer use an Arduino Nano to drive the CCD and plan on using a Teensy 3.6.
Adam wrote 06/20/2018 at 14:55 • point
Thanks! The progress on the driver has been pretty slow mainly due to a lack of time to devote to it.
I have't seen the teensy firmware, thanks for sharing, it will probably save me a lot of headaches and hopefully speed up my progress.
esben rossel wrote 06/18/2018 at 05:24 • point
I think you've designed a very elegant spectrometer. How is it going with your tcd1304-driver? You've probably already seen it, but there's a guy over the pjrc-forum who's written a Teensy firmware for this:
https://forum.pjrc.com/threads/52569-TCD1304-with-teensy-3-2
