For the diffraction grating I used a 600 l/mm holographic concave diffraction grating that I bought off of Alibaba for around $90. The concave surface of the grating serves to both collimate and focus the light eliminating the need for mirrors. This grating was design for use in a monochromator, measuring a single wavelength at a time using an exit slit, where the grating would be rotated about its central axis to change the wavelength of light impinging on the exit slit. However I found it does a fine job as a polychromator even though it is not flat field corrected.
Below you can see the highly detailed technical drawing and specs that came with the grating describing it's optical properties.
Zooming in on the drawing scribbled on the masking tape is the proper setup for the entrance and exits slits and the angle between them.
As you can see from the images below the surface of the grating isn't in perfect condition, but it still does the job.
