I finally got around to printing an enclosure for the spectrometer this weekend. To cut down in print time I removed most of the walls and will use aluminum sheeting instead. Depending on how that works out in the long run I may stick with it or switch to a fully plastic enclosure.
Spectrometer components. Both the grating base and the CCD hold are removable, for now. This allows me to rotate the grating to test out different configurations.
Grating, slit and CCD installed and illuminated with and LED flashlight.
Spectrometer walls. I cut these out of ~0.5mm aluminum sheeting and spray painted them black.
Enclosure with walls installed.
Assembled spectrometer, sans cover.
Next up I need to design a cover and drill a hole to allow for USB connection to the CCD controller.
Thanks! Yeah I bought the aluminum sheet from a local hardware store. Something like this: http://www.homedepot.com/p/M-D-Building-Products-36-in-x-36-in-Plain-Aluminum-Sheet-in-Silver-57000/100351161
That is very elegant. I'm slightly jealous I wasn't able to come up with an equally sexy and clever design. What is the thickness (and source) of the aluminium-sheets?
[I now see I didn't read the log properly, and my question(s) were already answered]
