Precision MAX6675 Module + K Type
Thermocouple Temperature Sensor for Arduino but actually using 2M Wire K Type Thermocouple
Temperature Measuring Probe Sensor
Arduino Nano to read the sensor and control of to RGB LED.
Please note that the method does appear not give a true temperature measurement. Particulary when the Heat Bedcools down.
I plan to change the MAX6675 Module to a different one.
MAX6675 Module works quite well but not well enough for me.
