I have the screen working from the battery pack, but anytime the Pi is under load, the screen blanks out. The datasheet for the regulator states it can supply a full amp, up to 1.3xx with a good heat sink. So I might end up adding a heat sink, but I'm thinking hard about just designing a different switchmode power supply for better efficiency
j0z0r pwn4tr0n
