During the week some parts (from China) arrived finally - some DHT11's (for humidity), a BMP85 (for pressure) and some additional D18B20 for temperature measuremenr. I'm planning to measure outside and innside temperature (under the rooftop near the ground) and soil temperature as well.
But as i'm still wating for my Dupont femals to put together the connectors and the weather is so beautiful i decided to work on the housing for the electronics (the PI, the sensor adapters, maybe later an LCD display).
I took some scrap wood and made some 45Deg joints with the saw, and a backside from plywood - i decided to go for 20 x 20 cm housing as it should give me enough space for forther extensions
The joints are just glued together and waiting to dry - later i'll mount them on the back plate. The front cover is not yet made...
