Now that the main componets are in place it is time to write something about the software part of the project:
At the core of the Greehouse PI i planned to have a RethinkDB database. It is aJSON based (noSQL) database which is mainly designed for realtime applications. It provides a mechanism called change feeds, which allows to watch any table (actually better called document store) for changes and trigger an action (similar to SQL-Triggers).
To install RethinkDB on the Raspberry it is necessary to compile the DB from source code. This step takes a while (more than 10 hours for me).
Very import is really to increase the Swap space on the Raspberry before starting the RethinkDB built, which is mentioned as a step in the tutorial but there is no detailed description give. Here is how to do it:
sudo nano /etc/dphys-swapfile
You will see the default value in the file:CONF_SWAPSIZE=100
Change it to CONF_SWAPSIZE=1024
and execute sudo /etc/init.d/dphys-swapfile stop
sudo /etc/init.d/dphys-swapfile start
That's it - and a free -m
should give youtotal used free shared buffers cached
Mem: 435 56 379 0 3 16
-/+ buffers/cache: 35 399
Swap: 1023 0 1023
After the built is done you can change it back to the original value following the same steps.
Now you can start to download and compile RethinkDB.
It is not as complicated as it sounds - you can find a quite good tutorial here:
https://www.rethinkdb.com/docs/install/raspbian/
After the build is done we still need to install the python drivers, which is really easy:
sudo pip install rethinkdb
Now that we have drivers and RethinkDB on the Raspberry we can add RethinkDB to start automatically after reboot (which is not done automatically by the install script).
There is different ways to do it - i decided to add a line to /etc/rc.local:
sudo nano /etc/rc.localand add one so that it looks like this:
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
# Print the IP address
_IP=$(hostname -I) || true
if [ "$_IP" ]; then
printf "My IP address is %s\n" "$_IP"
fi
/your/path/rethinkdb --bind all --server-name rbpi_rethinkdb -d /home/pi --daemon
exit 0
Make sure to add the path to the RethinkDB call - as the script might fail due to missing path settingsNow RethinkDB should be up and running after reboot, drivers are installed and we are good to go...
Also to put the data files of your database to some other location change the path after -d to something you prefer them to be (ideally a usb stick mounted location)
Reboot the system with a
sudo shutdown -r nowand after the system is up again run the foillowing
ps -elf |grep rethinkdb/
1 S root 2692 1 0 80 0 - 26711 - 11:12 ? 00:00:05 /home/pi/rethinkdb/rethinkdb-2.3.4/build/release_system/rethinkdb --bind all --server-name greenhouse_pi -d /home/pi/data --daemon
1 S root 2693 2692 0 80 0 - 13208 - 11:12 ? 00:00:00 /home/pi/rethinkdb/rethinkdb-2.3.4/build/release_system/rethinkdb --bind all --server-name greenhouse_pi -d /home/pi/data --daemon
1 S root 2774 2693 0 80 0 - 13208 - 11:12 ? 00:00:01 /home/pi/rethinkdb/rethinkdb-2.3.4/build/release_system/rethinkdb --bind all --server-name greenhouse_pi -d /home/pi/data --daemon
0 S pi 3538 3516 0 80 0 - 964 pipe_w 12:03 pts/1 00:00:00 grep --color=auto rethinkdb/
which should then give you a very similar result as the above output and tells you RethinkDB is running
