My code works with a clock face with a circumference of 72 cm now you could make it larger or smaller but you would have to adjust the code
I wanted to make a clock for my room that fit in with my weird creations, so I did :D
StepperMotor.cppThe cpp file of the library I usedcpp - 2.02 kB - 07/19/2016 at 19:35 |
StepperMotor.hThe h file of the library I usedh - 474.00 bytes - 07/19/2016 at 19:35 |
good
