11Step 11
Whew... now that we're in command mode and we have a serial connection to the master module we'll need to test if we can actually send commands. In Tera term hit ALT+R (you might need something in the clipboard.) Now type in AT and hit send, if you get an OK then all's well. If you have problems check out step four of this other post by techbitar.
12Step 12
Now setting the module to Master mode is as simple as sending the command AT+ROLE=1. If you get back OK then you've successfully set you're module to master role.
13Step 13
14Step 14
Connect you're master module to the UART pins of any MCU and you're slave module in the same way to another MCU and you've got Bluetooth communication.
15Step 15
