Two small 12 volt air pumps are now hooked in series and mounted in a backpack, to get 24 PSI of pressure. This eliminates the hose tether to the offboard pump. It is working fine but is still somewhat noisy. Work has begun on making a quieter pump that would work by compressing an artificial muscle with a gear motor cam.
