So the redesign is coming along nicely in my opinion.. Here's some shots of the assembly as it stands so far.. I'm in the process of printing these out as I type this so I will have some photographs of those soon... It was also suggested to me that I label things in the pictures...so here goes!
Here's the optics system up to the point of the beam splitter... I am starting work on the objective lens and cuvette tray assembly tonight..
A sort of top down view....
A view from the right...
A sort of view from the top down..
From underneath..
And from the top and above...
These modules are based on the optics I have purchased from eBay... It is my intention to make them parametric, and also provide direct links to specific optics you can purchase from places like Edmund and I will provide the parameters for each one.. This way it will allow for a very customizable option as well as a standard to base everything from...
Here is a sample list (NOT FINALIZED) for optics that I will be providing the parameters for... This is all from Edmund Optics.. http://www.edmundoptics.com/ Mind you......this list is all brand new components.....not from eBay, so the prices are higher... It may/will change and I may include other manufacturers, I want to find the best choices for the best prices....!!
- $15.00 Stock No. #69-245 4-6 Wave Mirror 25.4mm Diameter
- $85.00 Stock No. #69-867 550nm Dichroic Longpass Filter, 12.5mm Diameter
- $90.00 Stock No. #64-594 525nm OD 2 Shortpass Filter 12.5mm Diameter
- $140.00 Stock No. #45-111 12.5mm 50R/50T Standard Cube Beamsplitter
- $29.50 Stock No. #32-489 Double-Convex Lens, 25mm Dia. x 25mm FL Uncoated
- $175.00 Stock No. #68-843 532nm Hard Coated Laser Clean-Up Filter, 12.5mm Diameter
- $105.00 Stock No. #43-218 1800 Grooves/mm, VIS Holographic Grating, 12.5mm x 25mm
More updates soon!!!
Update! Here's some real photos of the above!
The beamSplitter mount just finished off the 3D printer....still has the supports under it..
A partially assembled test of the laser emitter case, the shutter, surface mirror and beam splitter...
I'll try to get better pics up soon!
fl@C@
