I'm still in the design process for some of the printed parts... but here is what I have printed so far...
- 1. Laser Emitter Mount
- 2. Mirror Mount
- 3. Laser Shutter Assembly
- 4. Beam Splitter Assembly
- 5. Beam Dump
- 6. Objective Lens Mount
I'm still designing the filter wheel assembly right now.. and then I will proceed to the rest...and the actual spectrometer... In the mean time, here's some terrible photos... It's apparently very difficult to photograph black plastic.. I'll try some better lighting as soon as I can..
The Mirror Mount
Mirror Mount opened up showing the inside...
Laser Emitter Mount opened up showing the inside...
Everything together that I have printed right now.. A similar angle to the rendered shot....
fl@C@
Yes, I had planned on coating the inside.. I ran a couple tests yesterday and today with the mirror, objective lens and the laser... My hopes was that the black plastic would possibly reduce a little, but it's too shiny in some places... I think a nice coating on the inside.. maybe even some light traps along the beam path, etc.. The 150mw laser is so bright it turns out, and the parts I printed so far are in 'medium' quality, that you can actually see the beam through the parts in some places... I need to increase the density of the prints (currently set to 20%-very low) and the quality, then run some more tests.. Another thing I noticed is the seam along the joints tends to leak a little light...so I need to add some beads or something around the seam which should help with the parts fitting better too.. My whole objective with this new design was to eliminate stray light and environmental light, etc.. I'd hate to create a whole new problem! But I think you're right.. Coating the inside would be very beneficial..
