Lift speed: 80mm/min
Layer height: 0.1mm
Exposure time: 8s
Time: 1h47
Without supports!
File : Adalinda - The Singing Serpent by Louise Driggers
A project log for uTopiaPrinter (SLA)
An resin 3D Printer working with LCD and UV LED's.
Layer height: 0.1mm
Exposure time: 8s
Time: 1h47
Without supports!
Few hours of life is the light source?
Hi.
You could develop a 3D printer using the Kickstarter crowdfunding.
Search in XYZ resolution of 25 microns. use resins third possibility.
I would like to be a Backer of your project.
Hello Jorge,
Thank you for your interest.
I will not make immediately a kickstarter campaign, but I plan to produce some alpha kits.
I would like to be sure that what I'm going to sell works well and for a long time.
