While doing some testing (well, more like probing with a loose wire....), I successfully achieved catastrophic melt your retina high voltage electrical arcing failure! I'll post a picture momentarily of the post short circuit PCB. This is why you never probe high voltage circuits unless you are insulated from said high voltage. Good thing I had the atMega out of it's socket at the time..... Well, on to revision two. I think I am going to revise the design to use a MOC2021 opto-triac trigger as I'm not having any success triggering the triac directly from the atMega, datasheet be damned. I may even decide to throw in an H11AA1 for zero cross detection simply to reduce the code complexity a smidge. The H11AA1 will give me an interrupt at each zero cross instead of every other one. Still researching :)
Rhys
