After removing all the plastics in the headphones i needed to find out how to actually make it from a headphone to a audio adapter.
After some time analyzing the board I saw that the audio in connector was in parallel with the speakers.
Great, so i only need to connect any other headphone in the audio in and it should output some sound?
Not so easy, once i connected something in the audio in the bluetooth processor would be turned off, it means that there is some signal connecting the audio in and the processor.
After some more analysis of the board I conclude that the signal DT (in the picture) was connecting the audio in to the microprocessor, and once i plugged the headphones it would be shortened and kill the processor, so i just cut it off =D.
DONE, just cut off the speakers and now my audio input is my only audio output.
finkel.rf
